zeleznikrg
Checking for 9.x versions of flash
In the past, I’ve used Advanced Installer to install flash, but now that Adobe has changed some of the naming standards, it’s gotten more complicated.
The ocx used to be named "flash.ocx", but now the name seems dependent upon the specific version (flash9.ocx, flash9a.ocx, flash9c.ocx, flash9d.ocx, etc).
How can I have the installer check to see if ANY version is installed and if none are to register whatever version that I package with the MSI?
I’m running version 5.2.2.
Cosmin
You can use the Prerequisite feature for this. In the "Prerequisites" page, in the "Software" tab you create a new prerequisite. In the "Install Conditions" tab you will specify a registry key as a search criteria. For example:
Registry key exists      HKLM\SOFTWARE\Macromedia\FlashPlayerPlugin
You can read more about this feature here:
http://www.advancedinstaller.com/user-g ... tware.html
If you don't want to use a prerequisite, you can use a registry search for the
key and use the RESULT_PROPERTY property to condition a custom action which will launch the Flash Player installation.
If you encounter any problems please let me now.
Cosmin
