Your product looks great! However I have run into a problem.
I am trying to create a simple install of some data files.
In "Install Parameters" I set ApplicationFolder="c:\myco\myapp"
In "Files and Folders" place some files for install in "ApplicationFolder"
Under this I have a sub-directory (say mydir) into which I place more files.
After build I run the msi on the target PC...
If I change nothing during install everything is OK.
If I change "c:\myco\myapp" to "c:\userspecified\myapp" the following occurs...
"c:\userspecified\myapp" is created and the correct files are installed there. The sub-directory is not created there.
The original directory structure is also created "c:\myco\myapp\mydir" and the files specified for "mydir" are placed here.
Also, I need the user to be able to install on a network drive say "x:\myco\myapp" but the installer is raising an error. I cannot even see any network drives using the "Browse" button. This works fine if I use MS Visual Installer to create the MSI file and ORCA to edit it.
Any suggestions?
