I need to run an exe before registering my attached ocx. Is this possible? It tries to register my ocx before running the exe. I can't find a way to reverse this.
Argh you're right. You can only run installed/attached files in your custom actions. I got confused because we are trying to add this feature to the 1.4 version.
The only way it would work is if you'd create an attached custom action with regsvr32 inside. Not nice I'm afraid...
