What version are you using? Is the project by any chance on a non-writtable drive or on a shared network drive? Are the template.msi and template.aip files in the folder where Advanced Installer was installed?
Can you please tell me exactly what you've done to fix the problem and how the configuration was initially? This way I can try to make sure this is fixed for anyone else.
