I have several merge modules that serve similar purposes. Which module(s) should be installed is dependent upon registry settings that I find. I have reviewed the "Install Level" comments for a feature, and recognize that I can associate a merge module with a feature. But the "Install Level" >= option doesn't seem to work for selecting which modules should be installed and which should be skipped. If I install module 1, I would not want to install module 2, and vice versa.
Is there another way of applying a conditional to the installation of a merge module, or applying the conditional within the merge module?
Thanks.
