Hi Cosmin,
thank you for your reply,
cosmin wrote:
I'm not sure why you are encountering this behavior. Can you please send us the .AIP (project) file you are using and a
verbose log of the install process with the problem to
support at advancedinstaller dot com so we can investigate them?
Well I know now
When installer is running for the first time it installs the drivers and it pops up the message to attach the device after install is finished...I did this..then I went into the project increased the product code and did an upgrade with cable still attached to the device...and when the second install/upgrade was running this window poped up...I came across this problem when just installing the software and the usb cable was still in the device...
If I remove the cable when upgrading or uninstalling the problem is gone
One sub question here, does the uninstall action happen when I do an upgrade?
cosmin wrote:
This error doesn't seem related to Advanced Installer. Most likely the problem is caused by the .NET Framework installer or by the target machine. You can download .NET Framework 2.0 SP2 from
here. You can also try testing the package on other machines.
Well I tried running the installer on different machines everywhere its the same error.
I will try with other .net framework prerequisites (.net 3.0)
Do you think that it would be better to embedd the .net framework in the exe bootstraper (is this even possible)?
Greg
PS: I still have two days of free evaluation, is there a way to evaluate after that? If the product will suffice our needs we are buying it asap because we are running short on time to create the final installer for our product!
