Hello.
I am trying to pass on a system DSN in the MSI file and continually get the following error message when installing on the user's PC.
"Error configuring ODBC data source: CODA (this is the name of the DSN), ODBC error 8:
Invalid keyword-value pairs. Verify that the file CODA exists and that you can access it."
The database is SQL Server 2000, is on the network and can be seen by the PC(s) I am installing to.
The keyword-value pairs for the system DSN in the registry (of the development PC) are as follows:
(Default) : (value not set)
Description : CODA Database
Driver : C:\WINDOWS\SYSTEM32\Sqlsrv32.dll
LastUser : CODADBA (this is the ID of the database)
Server : LWF03 (this is the name of the database)
What do I need to do to pass on the correct keyword-value pairs to the MSI file? I have tried to change the above entries around but always get the same error message on install.
Thanks in advance for some clarity in this matter.
Peter Tyler
Geneva - Switzerland
