- Download the MergeModuleProblem.zip
- Extract it
- It contains 2 files, 1 aip merge module, 1 dll.
- The aip file is a merge module that is supposed to point to the dll. So any installer that contains this merge module will package this dll.
- Go to the Project details->assemblies, you will get the below screenshot. This is expected. Note the version number
- Now, replace the dll with the one in the folder SyncfusionCoreLatestDll.zip. This dll's version (7.103.0.21) is different from the previous one (7.102.0.21)
- Go to the Project details->assemblies again, the dll is the same, but the version number is not updated
Is there anyway to synchronize between assemblies GAC with the assemblies I packaged? I need to always update my merge modules due to versioning change, so you don't expect me to synchronize the GAC all the time, do you?
