Ecold
Using Group Policy for distribution
I have created an msi file to install via Active Directory's Group Policy. Upon reboot, I get a screen showing that the managed software is being installed but it never leaves that screen. Could it be that since it is a trial version, it is hosing on the trial version notice? I can't buy this until I verify that the installation works on at least two test machines. We have about 800 to roll out this application to. I have tried several installers that are within our budget and this appears to be the best but if I can't get over this hurdle, I will have to look elsewhere. Please help!! I want to use Advanced Installer.
Ionut
I don't believe this is caused by the trial version notice. To verify this, create a MSI file using a simple project - this does not show a trial notice. Try installing this MSI via Active Directory's Group Policy.
If the problem still persists, please send us the AIP file, the MSI file and a screenshot to support at advancedinstaller dot com.
Denis
Denis Toma
Advanced Installer Team
