During a major upgrade the old version is completely uninstalled and the new version is installed. If you want to make sure that the original database file is not removed, you can try one of these approaches:
1) Use the
"Never Overwrite" and "Permanent" attributes for the component of the database. In this case the installation package should use a
custom action to remove the database for a complete uninstall.
2) Backup the database file when the new version is launched and restore it after the upgrade is complete. Please note that the User Guide contains the
Preserve File on Install how-to which may help you.
Cosmin
