I am after some advice on firing off custom actions using AI.
I have a package that deploys a number of scripts to a server. I then want to have a Installed Custom Action fire off one of the scripts. The problem is that I always seem to get an error message:-
Product: Domain Controller Support Scripts -- Error 1720. There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor. Custom action new.vbs script error -2146827864, Microsoft VBScript runtime error: Object required: 'wscript' Line 5, Column 1,
I don't believe its the script, even v simple scripts that normally work ok also get the error.
Any advise on what I could be doing wrong or examples would be greatly appreciated.
Many thanks
