how can i create a shortcut during install which prompts the user for username and password?
The normal way in windows explorer is to Right-click on the shortcut and select Properties. In the center area of the Properties dialog box find the checkbox labeled, "Run as different user". Select the checkbox and click OK to close the Properties dialog box.
thanks in advance,
wolfgang
