I would like to create a shortcut with the working folder to be the [sourcedir] (the place where the msi application is).
How do I do that?
Dave
I have tested the package on a Win98 machine and I could not reproduce this behaviour.this seems not to work when the install takes place on a win98 PC using the <InstMsiA.exe> etc support files.
This could happen only if there is an Execution Condition on the "Property Set with Formatted" Custom Action that prevents it from running. Moreover, if the CA is not executed, then the Property will still hold the default value ("C:\") set in the Install Parameters page.I assume the custom action that transforms [SourceDir]../ is not triggered.
MsgBox Session.Property("PSD")
