I get this error when I try to remove a file (.NET assembly) from the files in my Merge Module: "Can not delete file <filename>. It is referenced from another component."
I have deleted ALL the files, custom actions, services, assemblies etc.. but there is this 1 dll that I can not delete.
When I look at the TargetFeature in the Organization view, it still contains a number of components for the files that I have deleted. One of those components contains this dll that I can't delete.
I suspect it won't let me delete the file because it is referenced in that component? But then again I did manage to delete some of the other files.. Should those corresponding components not be automatically removed as well?
Also, the Delete option is greyed out for all the components in the feature (including for the files that have already been deleted). The only way around it seems to be to start from scratch and create a brand new merge module.
I am using Advanced Installer 6.2 Trial.
Mat
