hi,
How do you actually work this out.... I have many files link to a setup.exe so what i want to do is to group them together and extract them to the temporary folder of windows. here's the problem how do u remove the files after you have extract and automatically install the setup.exe meaning to remove the entire folder that is in the temp.
1. I did a custom action - Install- setup.exe( so that it will setup the installation)
2. I dun noe how to remove the folder that is being extract to the temp meaning when you install the folder "setup" is extract to the temporary folder and after installation " how do you remove it automatically"
Can advanced installer do that
