ERROR: TargetImages.Target string 'version1.1' is invalid; use 1 to 13 alphanumeric characters.
***** Log finishing: 2005-05-13 06:10:10 *****
error.
Exception - Reason: MsiMsp.exe failed to create the patch file.
Here is what I am doing in trying to create a patch.
1. Create a simple package called version1.aip.
Used all defaults, only added files and built it. Now I have a version1.msi.
2. Create another simple package called version1.1.aip.
Used all defaults, but changed product code from 1.0.0 to 1.1.0. When prompted to generate a new product code I said No. Also added same files as before except one file was newer (therefore I am expecting to actually update 1 file in the patch later!)
Now I have another aip, version1.1.aip.
3. Now I create a patch. Save it as version1.0To1.1patch.aip.
Clicked on the New Upgraded button and pointed to version1.msi.
Clicked on the New Target button and pointed to version1.1.msi.
Attempted the build, and then I got the errors noted above.
Please advise.
Michael Vitale
mjvitale@aol.com
703-772-2450
