Hello Brian,
You can achieve this using our
PowerShell automation support.
For example, the script below marks all file components from the "Common" folder as permanent:
$advinst = New-Object -ComObject AdvancedInstaller
$project = $advinst.LoadProject("C:\Your Application.aip")
function Set-FilesPermanentRecursively($folder) {
# Process files in the current folder
foreach ($file in $folder.Files) {
$component = $file.Component
$component.Permanent = 1
# Recurse into subfolders
foreach ($subfolder in $folder.Folders) {
Set-FilesPermanentRecursively $subfolder
# Get the "Common" folder
$selectedFolder = $project.FoldersComponent.Folders | Where-Object { $_.Name -eq "Common" } | Select-Object -First 1
# Run the recursive function
if ($selectedFolder -ne $null) {
Set-FilesPermanentRecursively $selectedFolder
} else {
Write-Host "Common folder not found."
$project.Save()
Please make sure to update the project path and folder name according to your project.
Hope this helps! Let us know if you have any questions.
