RubZ
Path issue/bugg building an .aip
Hello!
I need some help about this problem with this build to .aip.
We are trying to use a new folder with an new repository location with a clean solution (latest) but still "indexing" an icon in a previous path.
I attach the screenshot showing how that file isnt in the folder of the error. Is inside of all proyect, files, etc....
Also i pick the issue tab is empty and dont appear that error to try fix it (like previously errors i can fix like that)
Thanks and regards!
Ainstaller issue.jpg (379.39 KiB) Viewed 14018 times
Re: Path issue/bugg building an .aip
If possible, could you please share with me a copy of your AIP file by email at support at advancedinstaller dot com so I can further investigate this on our end and see if I can find the culprit?
