I would like to report the following issue:
You are working with AI version 23.4 with a new enterprise project.
You add a File Operation to your main folder, of type "File Removal" and select the options "Execute upon system reboot" and "Remove On Component Uninstall"
Entries are automatically added to the ActionText table with missing translations:
AI_AiRemoveFilesRebootDeferred: ActionText.Description.AI_AiRemoveFilesRebootDeferred
AI_AiRemoveFilesRebootImmediate: ActionText.Description.AI_AiRemoveFilesRebootImmediate
AI_AiRemoveFilesRebootRollback: ActionText.Description.AI_AiRemoveFilesRebootRollback
The following Localization Identifiers do not have translations:
ActionText.Description.AI_AiRemoveFilesRebootImmediate for languages:1033-English (United States)
Note also that projects migrated from older versions to 23.x also throws this error on conversion.
