Balaji
Could not access Network location
Hello team,
I am preparing an installer using Advanced Installer for my project. There is one scenario:
  • I am reading value from the registry to get the installation location of a specific software
  • If suppose there is an invalid value present in the registry, which I am trying to read from the registry, then the installer is throwing "Could not access Network location" error/pop-up
So, can you please let me know, instead of showing this standard message, can I display my custom message, like "The specified software is not installed on this machine".
Can you please confirm, is it possible to change the standard error message to a custom message?
Regards!
Re: Could not access Network location
Hello Balaji,
According to your scenario, I'm assuming that after the search in the registry for the path, you are using a property based folder.
If that is the case, I'm afraid the message can not be changed becuase that is a message thrown by the "CostFinalize" standard action.
This is a standard error message and has the error code 1606.
If we want to show a custom message, we might need to fail the setup ourselves via a custom action before the CostFinalize is executed.
