AquaComm
Suit Installer: How to daisy chain installation.
In the new Suit installer, are the Packages that are tagged "Always Install" or "Not Already Installed" installed in the order in which the package is listed?
I need to ensure that at least 3 of my 5 or 6 packages are always installed. Can I assume that the "Already Installed" conditions for the specific package are respected and some dimwit doesn't uninstall the Database Server :roll:
Re: Suit Installer: How to daisy chain installation.
Yes, the prerequisite should be installed in the order they are listed.
Not qutie sure what you mean by "Not Already Installed" as there isn't an option - you perhaps mean "Install prerequisites based on condition"?
Yes, those conditions should be in place similar to how our prerequisites work - the prerequisite will only be installed if the condition is false (meaning the prerequisite is not installed). Otherwise (if the condition is true), the prerequisite should not be installed.
Hope this helps! :)
