jusvu
Advnced Installer VS2019 integration stopped working
Hi! I have been using Advanced Installer for years and it has been working just perfectly. Now, for some reason, my existing Advanced Installer projects cannot be opened and I cannot even create any new Advanced Installer project in the Visual Studio 2019.
If I check the existing Advanced Installer project (part of my two project solution), it shows "load failed". If I then try to reload the project, Visual Studio shows "The operation could not be completed" popup window and the Output view has text "<mypath>\<myproject>.aiproj : error : Not found".
If I try to add a new Advanced Installer project (Right click solution -> Add -> New project -> Advanced Installer project), it just shows a popup "Not found" and refuses to create the project.
I don''t know what happened... Maybe Windows update broke something? I updated Advanced Installer to the latest 22.4 version and did the same for the extension in Visual Studio, then I tried to disable->enable the extension, but nothing seems to help. Any idea what might be wrong?
jusvu
Re: Advnced Installer VS2019 integration stopped working
It works now! The problem was Windows Management Instrumentation (WMI). After repairing that, Advanced Installer started to work OK. Case closed.
