nchounlapane
Retrieving install parameters from prerequisite installer
I have a main installer that has post-install prerequisites. From one of the prerequisites, I would like to run "Action to be run after this package installation". The prerequisite is another Advanced Installer project. Is there a way to have the prerequisite installer to set install parameters for the main installer to be retrieved in order to use "Action to be run after this package installation" feature? There are certain settings and parameters that get set from the prerequisite that need to be retrieved in conjunction with using settings and parameters from the main installer.
Re: Retrieving install parameters from prerequisite installer
What I'm thinking we can do here is write the parameters in the registry during the prerequisite installation and then retrieve those in a custom action in the main installer.
However, not sure how this would work since your prerequisite is scheduled to be installed after the main package?
nchounlapane
Catalin,
Thank you for your response. We have considered the registry solution but we decided on a different approach.
Nick
Hello Nick,
Glad you managed to find a solution. :)
