the gridlock
Run bat file in app folder?
I want to run a bat file but then I want to delete it.
The problem is that the application folder path is hard to determine, so I will put this .bat file in the same app path.
But how to delete this bat file now?
Update: Problem solved by Removal Tool
Thanks you!
Re: Run bat file in app folder?
Its great to hear that you've managed to resolve this.
