john.reasor@aaon.com
##[warning]Task 'Advanced Installer Build' version 2 (AdvancedInstaller@2) is dependent on a Node version (10) that is e
I am seeing this on every pipeline build.
##[warning]Task 'Advanced Installer Build' version 2 (AdvancedInstaller@2) is ##[warning]Task 'Advanced Installer Build' version 2 (AdvancedInstaller@2) is dependent on a Node version (10) that is end-of-life.
Re: ##[warning]Task 'Advanced Installer Build' version 2 (AdvancedInstaller@2) is dependent on a Node version (10) that
Hello John,
This is currently under investigation on our side.
In the meantime, can you confirm that this "warning" does not affect your pipelines in any significant way? For instance, despite the warning, is the setup package built as expected?
will.ellis
Is there any update on this? It happens for AdvancedInstallerTool@1 too.
Hello Will,
Apologies for the quite delayed reply on this!
I'm afraid not, as we can not quite reproduce this on our end.
It is indeed true that our task:
https://github.com/Caphyon/advinst-vsts ... ckage.json
requires a version of Node.js:
"@types/node": "20.12.12",
Can you try to manually install Node.js on your local build server machine where the self-hosted build agent runs? And see if this makes any difference?
Just try to follow the install steps exposed here:
https://learn.microsoft.com/en-us/windo ... on-windows
SimLoe
We had the same issue and found a solution, by simply changing the task version from 2 to 3 in the settings of the Advanced Installer Build Action in devops...
Hello Simon,
Thank you for your followup on this and for sharing your solution with us!
I am sure this will be of help for further users facing a similar scenario.
