rmoc
Condition based source files
I have a file appsettings.json which should be installed in my target directory.
However, I would like to select the source file depending on a condition. Although I can define a condition for the component, I can only ever define one file as the source file. I have seen that I can define the path to the source file using different builds. In this case, however, this is of no use to me as the condition can change at runtime. So probably the only way will be to copy the file manually from two different sources via custom action.
Is there an easier way to do this that I don't know? It would be very helpful for the future if you could define a target file from several different sources.
Re: Condition based source files
What I can think of to overcome your scenario (e.g. installing different appsettings.json based on a condition) is like this:
Note: let's consider we have two appsettings.json files.
- under "Application Folder", create two separate folders (e.g. 1 and 2)
- in each folder, add your appsettings.json
- right click on each folder and check the "Install content into parent folder" option
- in "Organization" page, condition each of your files to be installed based on the condition
rmoc
Hello Catalin,
Yes, that's exactly what I was looking for. Thank you
Reagrds,
René
You are always welcome, René!
Glad I was able to help. :)
Return to “Feature Requests”
