How do I sync or refresh the files and folders when i use command line to build .aip project?
I add some folders to my application then open project with "graphic interface" to build, it works will. But if I use command line to build, the adding folders didn't packaged into .msi.
I'm using 21.2.2 version and the build command as ""C:\Program Files (x86)\Caphyon\Advanced Installer 21.2.2\bin\x86\AdvancedInstaller.com" /build "xxx.aip""
The 18.5 version will auto sync folder when using command line to build but 21.2.2 version not!!
Thanks!
Best Regards,
Justin
