Dear all,
I've the Problem that i've to publish an Installer Package, in which we has some Settings and Files to deliver.
On Win10 LTSC2021, the script works flawless directly, when i use Custom Actions and let the Script from File execute.
On Win10 LTSB2016, it don't works from the custom actions. It will not run and in Eventviewer you see the Package was installed with code 0 whichi means success.
But if i trigger it manually from the powershell commandline it runs without any problems...
For me it's a problem, i had to publish versions with a wider Support from Win LTSB2015 - LTSC2021 and Windows Server 2012R2 - 2022.
Actually i only know it works with Win10 LTSC2021 and Windows Server 2022, the LTSB2016 NOT Working, the others are not already tried because of priority...
Can i give you some additional Informations to face down the problem?
Markus
