NovaES
File association problems
When I create a file association and check the "Windows 11 Context Menu" option, when it is installed it gives me an error and the installation or migration is canceled.
If I disable this option, it works correctly.
What is happening?
Re: File association problems
I'm not sure why this happens.
To facilitate a more in-depth investigation of this issue, could you kindly email the following resources to support at advancedinstaller dot com?
1. the .AIP (setup project) file
2. a download link for your setup package
3. an installation log
4. the build number and version of the machine's operating system where you can reproduce this
