toonetown
Control service control operation actions based off of property
Is it possible to control the service actions based off a property? For example, under Resources > Services > Control Operations > My Service > Actions > On Install, I want to select "Start" when the property is not set, and deselect "Start" when the property _IS_ set.
Re: Control service control operation actions based off of property
Unfortunately, it is not possible.
However, you can work this around by starting your service through our predefined "Start Service" custom action.
You can then condition this custom action to be executed based on your property.
toonetown
Thank you - we will investigate implementing that.
You are always welcome!
