MikeMcLoughlin
Signing with certificate on Azure keyvault fails
This feature has been working perfectly since September but in the last couple of days has failed every time.
My suspicions are that the response from Azure has changed somehow recently.
The error response in Advanced Installer is:
Could not read server response.
Advanced Installer 21.3.1 build 69aaef70
*** Stack Trace (x86) ***
[0x76749392] RaiseException()
[0x69ce7e86] CxxThrowException()
[0x014fae48] -----
[0x70ecc4ec] HttpQueryInfoW()
[0x00e80000] MODULE_BASE_ADDRESS
Re: Signing with certificate on Azure keyvault fails
I replied on the other thread debating this issue.
You can check my reply here.
Can you please download and use the following debug version of Advanced Installer 21.5? And let us know if this makes any difference?
This includes some improvements we hope will fix this issue.
AlexThunder
Is installing the debug version 21.5 still your recommendation to resolve this issue? I'm facing the same problem using azure key vault when it comes to signing.
Hey Alex,
In the meantime, we have released the official version of 21.5, which you can find on our Downloads page:
https://www.advancedinstaller.com/download.html
MikeMcLoughlin
This has been working perfectly since the hotfix but since Version 22 has reverted to the original reported problem.
Hey Mike,
I'm sorry to hear you're encountering the problem again.
We'll investigate/test this on our end and I'll followup as soon as I will have more information.
Hopefully, we'll be able to reproduce this on our end as well (fingers crossed). :)
Thank you in advance for your patience!
Update: we've tested this on our end and the signing worked with all our test certificates.
If possible, could you please give me some more details about the error you are encountering? Is it the same as in the first thread/post?
Did you change anything lately regarding the signing process (e.g. the certificate)?
