CharlesMa
VooVMeeting repackage problem
I have repackaged the VooV Meeting exe installation package into msi for software distribution in the Microsoft Company Portal which requires slient installation. I got a problem here when running the repackaged msi file that pops a window out says "please attach your device to this computer any time after the installation has finished" and the installation process terminated automatically.
Re: VooVMeeting repackage problem
From your description, it would look like the EXE package had a MessageBox custom action with that message.
You can check this by opening the repackaging project in Advanced Installer and checking the "Custom Actions" page for that.
Additionally, is the product installed on the end user machine or this messagebox also fails the installation?
