All,
I am using Advanced Installer Professional (just updated to 21.3 before this issue) and registered two files in my MSIX package. It installed fine, I tested it, and uninstalled it.
I built a different version of the same MSXI app and continuously get the error:
App installation failed with error message: An internal error occurred with error 0x800703FA. See http://go.microsoft.com/fwlink/?LinkId=235160 for help diagnosing app deployment issues. (0x800703fa)
It happens when I attempt to install the MSIX package after an Advanced Installer build.
Opening the event viewer to get more details, I get:
ErrorText Package could not be registered.
ErrorCode 0x80073cf6
Another Error on the same attempted install is:
ErrorCode 0x800703fa
ErrorMessage Illegal operation attempted on a registry key that has been marked for deletion.
CategoryName windows.stateExtension
This is confusing and just started after I registered several files in my previous build. I registered a *.exe and a *.dll during the build that seems to have caused the problems. Registered them using the native registation.
Any suggestions how to fix this? I tried a CCCleaner Registry clean but did not work.
Thanks.
