I renewed our code signing certificate this month and it was delivered as a physical token rather than a .cer or .pfx file. I activated the token so it's now in the local certificate store and it works fine. The only issue is that I'm required to enter the token password half a dozen times when generating the installer.
When the cert is on disk, it's possible to have AI store the password in the installer. Is there a way to do that when using a certificate from the certificate store?
I can export the certificate from the token to a file; is that the best alternative?
Thanks --
