NovaES
Some antivirus detects Advanced Installer installers as a Trojan
Hello, in the Kaspersky version and other antiviruses, the following installer libraries when it is generated and installed for the client, the antiviruses detect the following installer libraries as a Trojan.
Can you report that they are false positives?
Re: Some antivirus detects Advanced Installer installers as a Trojan
This is a false positive, I ensure you. Nowadays, antivirus heuristics are changing daily and becoming increasingly aggressive.
We scanned the related files on the VirusTotal platform and they were not detected.
I also uploaded the files on the Kaspersky File Analysis portal.
Can you please send us a screenshot with the detections from your Kaspersky antivirus so we can forward them?
You can also try submitting your setup package for whitelisting to Kaspersky and see if that helps.
NovaES
Can you tell me the link to send my installer to Kaspersky?
It's the same link I posted on my previous reply: File Analysis portal
You can also check the following article: Kaspersky: how to report false positive
