andy.garratt
Uninstall pre-requisites in certain order
Is it possible to uninstall pre-requisites in a different order to what they are installed? For example we have a pre-requisite which is a driver, and then a second pre-requisite which is reliant on the driver, then the application.
So the install sequence is:
Pre-requisite 1
Pre-requisite 2
Application
However, the uninstall sequence should be
Pre-requisite 2
Pre-requisite 1
Application
Cheers, Andy
Re: Uninstall pre-requisites in certain order
Hello Andy,
I'm afraid that the prerequisites order can not be changed.
They are installed in the order specified in the "Prerequisites" page.
