I've encountered an issue: I want to reboot pc after application is uninstalled, I have a [REBOOT] Force added on the finish button of the maintenance exit dialog. Now when I run the installer and press finish on the exit dialog, I am getting a prompt that restart is required, but nothing happens after I select Yes. Not sure what could be the problem.
Note:
I tried removing all the conditions from the [REBOOT] Force and all custom actions happening on uninstall - the problem still persisted.
I'm using Advanced installer version 20.9.1. In older 19.6 version restart worked as expected
