tserg
AI_GetMsiProperty returns empty result
hello,
i have an installer which works pretty well usually. At some step it asks user for credential and does a check. It looks into AD and does other stuff. There is one system which does not allow powershell custom action to retrieve user name:
=== code ===
$userName = AI_GetMsiProperty USER_NAME
$userPassword = AI_GetMsiProperty USER_PASSWORD
Write-Output ( Get-Date ) "check whether ""$userName"" exists in AD"
leads to
=== log output ===
check whether "" exists in AD
USER_NAME and PASSWORD are attached to standard LogonInformationDlg
please let me know if there is anything obvious to check. I have limited access to this system, so need to prepare well.
Re: AI_GetMsiProperty returns empty result
Are you sure that there was something input in the EditBox control?
If so, then the PowerShell script should have returned the correct string for the USER_NAME property.
It would help if we could check an installation log (verbose) from that machine.
The only scenario I can think of would be if the custom action is scheduled to run on "deferred" stage, without passing the properties to the "Parameter Values" field.
How to access installer properties from deferred custom actions
But considering you mentioned this only doesn't work on a single machine, I don't think this would be the case.
tserg
Catalin,
i was told they put credential in the boxes, also i can see log entries telling me so.
this custom action is attached to UI trigger and usually works well.
could you share an address to where i can send the log?
upd
we addressed this issue with using another machine.
You can share the resources by email at support at advancedinstaller dot com.
upd
Note quite sure I understand this, is the issue resolved?
If so, we can consider this ticket closed.
tserg
Catalin,
thank you. I think this issue is resolved for now.
You are always welcome!
Glad to hear the issue is resolved now. :)
