curt.blunt
Powershell Inline Script - Font install
I would like to install Lato font as a custom powershell inline script that runs at the Wizard Dialog Stage
The script runs fine, however the fonts do not get installed, I don't think it can find the font files correctly - what is best procedure to install something placed in APPDIR location
param($AppPath)
$AppPath = $AppPath.TrimEnd('\')
write-output "Path = $AppPath"
cd 'Resources\Fonts'
Copy-Item "Lato-Bold.ttf" -Destination "C:\Windows\Fonts"
Copy-Item "Lato-Light.ttf" -Destination "C:\Windows\Fonts"
Copy-Item "Lato-Regular.ttf" -Destination "C:\Windows\Fonts"
Copy-Item "Lato-Thin.ttf" -Destination "C:\Windows\Fonts"
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts" /v "Lato Bold (OpenType)" /t REG_SZ /d Lato-Bold.ttf /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts" /v "Lato-Light (OpenType)" /t REG_SZ /d Lato-Light.ttf /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts" /v "Lato Regular (OpenType)" /t REG_SZ /d Lato-Regular.ttf /f
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts" /v "Lato-Hairline (OpenType)" /t REG_SZ /d Lato-Thin.ttf /f
Re: Powershell Inline Script - Font install
Hello Curt,
Most likely, the issue in your case is that you are executing the custom action early when the files are not availalbe to your custom action.
To avoid this, you can add the fonts as temporary files.
