Restart Manager also successfully closes apps that have files in use.
(SERVER) MSI (s) (A8:C8) [21:39:07:920]: RESTART MANAGER: Will attempt to shut down and restart applications in no UI modes.
(SERVER) MSI (s) (A8:C8) [21:39:07:920]: RESTART MANAGER: Detected that application with id 18208, friendly name 'XSplit VCam', of type RmUnknownApp and status 1 holds file[s] in use.
(SERVER) MSI (s) (A8:C8) [21:39:07:920]: RESTART MANAGER: Detected that application with id 19832, friendly name 'CefCOM3 Process', of type RmUnknownApp and status 1 holds file[s] in use.
(SERVER) MSI (s) (A8:C8) [21:39:07:920]: RESTART MANAGER: Detected that application with id 20284, friendly name 'CefCOM3 Process', of type RmUnknownApp and status 1 holds file[s] in use.
(CLIENT) MSI (c) (B4:CC) [21:39:07:926]: RESTART MANAGER: Session opened.
(SERVER) MSI (s) (A8:C8) [21:39:08:399]: RESTART MANAGER: Successfully shut down all applications in the service's session that held files in use.
(CLIENT) MSI (c) (B4:CC) [21:39:08:414]: RESTART MANAGER: Successfully shut down all applications that held files in use.Code: Select all
(SERVER) MSI (s) (A8:38) [21:39:25:504]: Propagated Reboot to the client/parent install.
(SERVER) MSI (s) (A8:38) [21:39:25:504]: Value of RebootAction property is
(SERVER) MSI (s) (A8:38) [21:39:25:504]: Windows Installer requires a system restart. Product Name: XSplit VCam. Product Version: 4.1.2210.2601. Product Language: 1033. Manufacturer: XSplit. Type of System Restart: 1. Reason for Restart: 1.Why does this happen? What does "Reason for Restart: 1" mean? Is there a bug or misconfiguration w/c causes the Restart Manager to require restart despite successfully closing apps w/ files in use and for the restart prompt to not appear?
