We are currently using Advanced Installer to install an Excel Add-in.
We are currently building the executable with the Install Parameter value set to "Per-user only". This installs and registers the Excel Add-in correctly and we can see the option is added in the Excel ribbon.
We have a new requirement that we have to have the ability to install either 'Per-user' or 'Per-machine' based on what our users select. When we use the Install Parameter value "Per-machine if user is administrator, per-user otherwise" with 'Everybody (All users)' selected the installation finishes without any error. However, we are unable to see our Add-in when we open Excel. We also cannot see our Add-in under Excel Options > Add-ins.
There is no change in the above two scenarios other than the Install Parameters.
Are we missing any steps? Is there any additional configuration required for using the "Per-machine if user is administrator, per-user otherwise" option?
I have emailed my AIP file through to support at advanced installer dot com.
