manishCh
Skipping the Select Location dialog in run-time
I want that while installing my product, the decision that whether the Select Location dialog is to be presented or whether certain specific location is to be used should be taken at run-time. This decision may depend on certain value in the registry.
Please help me, How to do this? :?
UdreaMihai
I'm afraid that isn't possible yet just by using Advanced Installer. You need to use ORCA or a similar tool to edit the MSI package directly.
Best,
Udrea Mihai
Advanced Installer Team
