ddegange
Failed to load Java VM library (errno=126)
My operating system is:
Windows XP Media Center
Version 2002
SP2
After the successful install I am getting this message. Using Java 1.6 in the AI build.
This application has failed to start because MSVCR71.dll was not found. Re-installing the application may fix this problem.
Failed to load Java VM library: c:\daycare management system\jre\bin\client\jvm.dll (errno=126)
Can you help please. Thanks
Cosmin
Please make sure that the Java bundle you have included in your installation package contains the "MSVCR71.dll" file (in the "Files and Folders" page).
If the file is present and the problem persists, please send us the AIP (if it doesn't contain confidential information) or a small test case reproducing this behavior to support at advancedinstaller dot com so we can investigate this issue.
Cosmin
