cadull
NewPrerequisite: registry value does not exist
I'm adding a number of new prerequisites from the command line, each having three install conditions. Two are covered by the search types FileVersion and RegValue, but how can I check that a registry value does not exist?
Re: NewPrerequisite: registry value does not exist
I have done some testing and it looks like the "Registry value does not exist" criteria is not currently available in our command line support.
I have added this enhancement on our TODO list and hopefully it will be available in a future version of Advanced Installer.
cadull
Thanks Catalin, I think I can work around this limitation by moving the prerequisite from preinstall to postinstall and establishing searchable criteria during the install.
You are always welcome!
I believe the easiest workaround here would be to manually add the criteria in your project for each of your prerequisite. I am not quite sure changing the prerequisite sequence will help here.
Please let me know if there is anything else I could help you with and I will gladly assist.
This improvement has been added in version 22.7 of Advanced Installer.
cadull
Thanks Catalin.
You are always welcome! :)
