a.guelle
[solved] Download of older versions
Hi AI-Team,
as removed some features in the current version that we mandatorily need (i.e. TestODBCConnection), it would be nice if we were able to download older bugfix versions of previous major releases. Your version history links always to the current version.
Angelo
Re: Download of older versions
Hi Angelo,
The "TestODBCConnection" problems should be solved in the latest version of Advanced Installer (17.4) that was just released. Can you check that?
In order to download an older version of Advanced Installer you can go to the "Customer Information" page, enter your license key and click "GO".
On the next page, below the information about your license, you can select one of the Advanced Installer versions available for your license from the "Previous Releases" section and download it.
a.guelle
Hi Eusebiu,
the dowload works great, thank you very much.
Angelo
Re: [solved] Download of older versions
This is great. Thank you for your confirmation on this.
Return to “Feature Requests”
