The problem you are encountering might be related to a bug that is present in version 3.9 of Advanced Installer (which has already been fixed). In some situations, the language for a Simple project is not set to "English" (the only language supported by this type of project).
There is a simple workaround for this bug, though: in the "New Project" dialog, if the "Language" combobox shows a language other than English when "Simple" is selected above, then first click on "Professional", then click again on "Simple" (if you wish to create a Simple project). Now, the "Language" combobox should contain English.
Another workaround would be to delete the following registry key:
HKCU\Software\Caphyon\Advanced Installer\New Project\Last New Project Language
If this is not the case please send the AIP file to support at advancedinstaller dot com and then I shall investigate.
Ionut
