crowder
Azure Ocean Bubbles theme msi display issue
I am using Advanced Installer 16.3. I have two installers an exe and an msi. They both use the Azure Ocean Bubbles theme.
For the msi images and certain things don’t display correctly as they do on the exe. In the case of the image it is png containing a company logo and a transparent background. The logo displays on the exe and you can’t tell there is a background on the image. Whereas, on the msi you can tell there is a background. Please could you let me know if there is a way to resolve this.
Re: Azure Ocean Bubbles theme msi display issue
Hello Crowder,
The "Azure - Ocean Bubbles" theme requires an .EXE package type alongside with the "Enhanced User Interface" option. With that being said, I am afraid that this theme is not usable in an MSI package.
By default, when you choose this theme, your package type is automatically to .EXE and the Enhanced User Interface option is enabled. If you switch back to MSI, the Enhanced User Interface option will be disabled and the it will no longer be able to render the theme.
