crowder
Command Line Options to Set Images and the Exe Icon
We are using Advanced Installer 16.3. We have created jobs in Jenkins to build exe and msi files from Advanced Installer projects and use the Additional Commands to set values according to files retrieved from source control. Is it possible to use command line options to set images on the Exit and Welcome Dialogs and set the exe icon. To set the images I have tried SetProperty and couldn't get this to work. I was setting the AppLogoIcon to the image path. We are currently using relative paths and storing them on the machine to do this.
Re: Command Line Options to Set Images and the Exe Icon
Unfortunately, as for this moment, we do not have command line support to set either the EXE icon or icons from the dialogs.
However, I have added this on our TODO list and hopefully this will be added in a future version of Advanced Installer.
I will update this thread when this feature will be added.
Please let me know if there is anything else I could help you with and I will gladly assist.
This improvement has been added in version 23.4 of Advanced Installer.
