Hi guys!
What I need to accomplish is to install the files with the installer in a folder that the installer would create based on the name I would put in the user registration form.
In other words, I would need to created a variable based on the name I would put in the registration form so that the installer would install the files in a path that would look like this:
D:\New DacoTech Client CD Setup\[Organisation name]\DacoTech Estimator Backup
The registration form would only be used to make the variable "[Organisation name]".
Is there a way to remove the User Name and Serial Number field in the User Registration Dialog, because I won't need it in this case.
DAn
