Hi!
First of all, I am new to Advanced installer and I realy like the easy to go interface. But as there is not even a short manual, I do have some questions:
1. How can I create a shortcut in any folder? I have used the context menu in the "Application Folder" to create a shortcut in "Application Shortcut Folder", but I did not manage to make a shortcut to "Desktop" or "Start Menu/Programms/[Programname]".
2. What is the difference between "Application Shortcut Folder" and "Start Menu/Programs" folder? And what is the difference between "Application Folder" and "Programm Files"?
3. Is it possible to create MSI files with languages other than English? I do not have problems with the english UI of your program, but I would like to provide a german version of the installation for users of my program. Or does this depend on the installed version of Microsoft's Installer package? (to be sure: I would like to have "Welcome to ... Wizard" and "Click the Finish button" and other texts that appear during installation of my program to be translated)
4. Where is the GUID? I did not find an information about what GUID is used to identify the installed programm, so that updated version of my programm will replace old versions.
5. When running the created MSI file a second time, the "Modify" option allows to choose "Main feature". Is there a way to define these features?
Ok, thats all for now. Thanks for your software, it is a nice little tool which provides great help!
